a little plasma help
发表于 2021-9-1 00:41:23 | 显示全部楼层 |阅读模式
i am new to plasma cutting and was wondering if anybody could point me in the direction of hints, tips, suggestions...............im sure they are on this site i just cant seem to find them........i know nothing about this so the basics would be nice...........thanks in advance
Reply:make sure you use a filter or an air dryer to prevent water from the compresser going through your machine, its hard on consumablesNothing Ever Got Done By Quitting, Never Give Up.
Reply:A lot of guys cut too slow with plasma. You get your best cut usually moving fast, usually almost to the point that you out run the cut.X2 on the dry air..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:If your making a straight cut, tack a piece of angle iron to your work piece, and cut at a steady speed. With practice your "guided" cuts will look almost like they were cnc cut. very little kerf and slag.
GMT+8, 2025-12-21 09:00 , Processed in 0.071218 second(s), 18 queries .
