spot welder update
发表于 2021-9-1 00:41:22 | 显示全部楼层 |阅读模式
I just got my new toy for the spot welder. I ordered one of those $20 variable speed router boxes to see if that would work. It`s a 15A variable SCR.Works like a charm!! Now for thin stainless I can shange the settings down right to the point where it barely gets it warm!
Reply:Originally Posted by rhubarbrayI just got my new toy for the spot welder. I ordered one of those $20 variable speed router boxes to see if that would work. It`s a 15A variable SCR.Works like a charm!! Now for thin stainless I can shange the settings down right to the point where it barely gets it warm!
Reply:Try this.http://cgi.ebay.com/POWER-TOOL-VARIA...item2c517e3cd3By the way, I see you have Blackbird under your posts. You wouldn`t happen to have one do you?! Or are you a fan of the aircraft?
Reply:Glad to hear it works. Even more surprised that it even works! Those speed controls work with A-C universal motors, the type with brushes and should be used with A-C only devices. Go figure?
Reply:Originally Posted by rhubarbrayTry this.http://cgi.ebay.com/POWER-TOOL-VARIA...item2c517e3cd3By the way, I see you have Blackbird under your posts. You wouldn`t happen to have one do you?! Or are you a fan of the aircraft?
Reply:Originally Posted by transitGlad to hear it works. Even more surprised that it even works! Those speed controls work with A-C universal motors, the type with brushes and should be used with A-C only devices. Go figure?
GMT+8, 2025-12-21 08:44 , Processed in 0.132507 second(s), 18 queries .
