查看: 13|回复: 0
I have to cut some 150 x 50mm aluminium hollow section
发表于 2021-9-1 00:41:22 | 显示全部楼层 |阅读模式
I was going to use my abrasive drop saw but read that thread about cutting aluminium sheet.I only have to make 4 cuts.C'mon, the chop saw will be fine, won't it?I'm going to get the bits anodized after they're cut.ScottYeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
Reply:Clamp them to a regular miter saw with carbide blade.  You have to use a clamp!  You don't want to know what happens when a piece moves.My name's not Jim....
Reply:Hmmm. I don't have one of them. I've got a cut-off saw or some hand held circular saws. Looks like a trip down the road to my mate's place.Yeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
Reply:You're using a steel abrasive instead of aluminum ??
Reply:Originally Posted by scott brunsdon Looks like a trip down the road to my mate's place.
Reply:Yeah, Sandy, it would be the blade I use to cut everything. I didn't realise there were aluminium blades? For the sake of a couple of cuts, I'll go down the road - Tony owes me a beer anyway.Yeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
Reply:Originally Posted by scott brunsdonYeah, Sandy, it would be the blade I use to cut everything. I didn't realise there were aluminium blades? For the sake of a couple of cuts, I'll go down the road - Tony owes me a beer anyway.
Reply:Cutting aluminum with an abrasive blades causes the aluminum to gum up the blade, gum up the cut edge which makes for a very nasty cut edge, and will  have to ground off with a sandpaper wheel before any welding can happen on that edge.   Use a carbide toothed blade in any appropriate wood cutting saw (miter saw, circular saw, table saw), or use a band saw, jig saw, or sawz-all reciprocating saw.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Flexovit in OZ do AL abrasive blades.  They clearly have AL on them.The writing is blue colour for AL.Stone blades have green writing.Steel blades have red writing.And then there is the fine cut which is a INOX/stainless bladeI thing i got most of it right.
Reply:Thanks all.An AL abrasive blade would be handy, Larry. You reckon Bunnings would have them?ScottYeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
Reply:Originally Posted by scott brunsdonThanks all.An AL abrasive blade would be handy, Larry. You reckon Bunnings would have them?Scott
Reply:4 cuts, on some hollow aluminum?Just use a hacksaw and you'd be done by now.    The best laid schemes ... Gang oft agley ...
Reply:Little bandsaw would be handier
Reply:Originally Posted by scott brunsdonI don't reckon I've ever managed to make a straight cut with a hacksaw. And I readily accept that this is due to operator error.
Reply:Okay, just for a giggle I'll get the hacksaw out on the weekend. Might even get a new blade.Yeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
Reply:Originally Posted by TEKIts rectangular tubing...mark all four sides and make four cuts, dont try going all the way through with one cut...
Reply:Originally Posted by scott brunsdonOkay, just for a giggle I'll get the hacksaw out on the weekend. Might even get a new blade.
Reply:Scott, PM me your address and i will send you out some AL abrasives in the post.No charge...You should get them in a couple of days.
Reply:Gee, Larry, that's a generous offer. I'll do it now. Thanks.Yeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
GMT+8, 2025-12-21 09:01 , Processed in 0.091745 second(s), 18 queries .
