24ga stainless steel....
发表于 2021-9-1 00:41:16 | 显示全部楼层 |阅读模式
Butt welding 24ga s/s is a little tricky...   But I am the Man. Attached Images
Reply:i knew you could do it  i don't have a spunky username just what it is, me!
Reply:That looks really neat!But does it really float??  Got any pictures of it in the water?
Reply:Pretty cool ! TIG welded , I presume?
Reply:Sure it floats, it even floats upside down...   This one is set up for running SLS in IMPBA.
Reply:Too bad you pollished it I realy wanted to see the color you had.
Reply:Hey if you think you are so good. In your spare time try this. Full pen on all the AL and SS projects Purfect color on the SS inside and out. This is only a glimps of some of the things I did for training for the US open weld trials. Have fun.  Attached ImagesPre Trial World Skills Contest-Model.PDF (127.8 KB, 168 views)
Reply:(Weldengineer) I hate Adobe files. If you are so good, fix it where we can see it here. No polish needed......Thats the way the metal comes........  Attached Images
Reply:i've been all over the country and have seen different welders at all phases and "degrees" and i would hope you are not all that arrogant to believe ""Hey if you think you are so good"" would show any sort of respect at all !!! although i don't doubt your ability principles and theories and weld trials doesn't mean anything until you are competent in "real" world fab and technical work.i would hope you could show some respect on the board!!!!!  i don't have a spunky username just what it is, me!
Reply:Paul, I have been fabing all of my life. I have all the welding experiance I need. Most likely I have more than you. I have worked in the oilfield, Areospace, and fabshops. The weldtrials are like the olimpics of welding. It is a great achievement to make it that far because that covers two years of competition. So to make it to the top six of 110 competitors is pretty damn good. So do not tell me I do not have real world experiance if I can weld fluently with all welding processes. Whether in competition or production situations.And I was only trying to see the experiance robinhood had.
Reply:this post will probably get pulled but......for being 22 yrs. old  you sure are not of the same mold of most here on the board! i could care less about your welding adventures and welding "olympics" or your knowledge of the art of welding, i just wish you could show some respect to fellow welders!as far as my experience that has NOTHING to do with your arrogance. 1 out 6 or #6 out of 110 is great, but a wiseman said " if 2 welders are sticking plate and both are 100 pen, beautiful bead and cut they're both great.it doesn't get better than that". as far as ROBIN HOOD i doubt you or your classmates will ever be able to duplicate his knowledge of his "THE PROCESS OF WELDING" or as he puts it "stickin' metal.  i don't have a spunky username just what it is, me!
Reply:Any body else want to crash my post....  I hope this doesn't get pulled, it can be done and I have had a lot of fun building it, and racing it.Weldengineer, I will say this one more time.  Put up or shut up. You can call me Mike, everybody else does, thats needs something done. do you have a real name?
Reply:Yes, its Chase. I did not want to affend enyone but I am a welder always have been always will be I just wanted to see the experiance you have. Paul took it the wrong way. I am good at welding but I know the details. I have to fight hard with welders because they think I am a stupid engineer that knows nothing. But the fact is I can weld just as good as they can. so my question is what do you want me to "Put up or shut up"? and also I did not have to spell in that comp.
Reply:whatever........  i don't have a spunky username just what it is, me!
Reply:Chase, you have not made to many people Madd or is it mad...  when I was twenty two, I would tell the old guys to get out of the way............all I was trying to do was get home on time so I could see my kids before it was time for them to go to bed. I wish you all the luck in your new field.....but I need some proof of who you are, or who you want to be........got any pictures of some stuff you've done.....
GMT+8, 2025-12-21 07:49 , Processed in 0.066190 second(s), 18 queries .
