What does duty cycle mean?
发表于 2021-9-1 00:41:14 | 显示全部楼层 |阅读模式
Thanks in advance!
Reply:Read this.http://www.millerwelds.com/products/...e/basics6.html
Reply:Thanks!
Reply:It is how a welder is rated for the time it is used.  Bascily if it is rated at 20%  at full power then you could weld for two minutes out of ten  of course you could weld longer at a reduced setting
GMT+8, 2025-12-21 11:37 , Processed in 0.093005 second(s), 18 queries .
