--------------------------------------------------------------------------------I was able to get a very very good deal on a new Miller spectrum 1000 the problem is first off im a newb at all of this and second off it came with a machine held torch instead of a hand held torch. It is this model #SPECTRUM 1000 80A 25FT ICE-80TM, AUTOMATION KIT http://www.millerwelds.com/products/...000/models.phpthe one for $4375.00Do you think i should try to sell just the machine held torch kit with the acessories or just try to trade straight up for a hand held torch???Can you give me some guidance on what you think i should do? I will only be using it around the house for projects and im also fixing to get a hobart mig 210 the first reason i found this forumThanks in advance for your help
Reply:Hi Ya killintime you may want to ask your question in the Miller forum here at Welding Web you find more folks and maybe someone wanting to exchange with you or maybe buy the torch.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back. |
