Homemade smoker
发表于 2021-9-1 00:41:07 | 显示全部楼层 |阅读模式
I'm new here but I did read where somebody mentioned smokers. Here are a couple of my babies I'm working on a third. I shoul'nd give up a secret but what I use is water heaters. The REAL trick is to weld two end-to-end so you have a nice shape on both ends. Attached Images
Reply:how many gal. and how many pounds of meat can you get in there another good project for the welding web ! thanks for some ideas  i don't have a spunky username just what it is, me!
Reply:I usually use the 40gal. which plumbers are usually more than happy to give away. The other thing to look at is. if you use two keep looking till you find two of the same brand so the diameters match. I can usually do 4 good size pork shoulders on them with room to spare. Good luck. Any one else got any suggestions or photos?
GMT+8, 2025-12-21 11:35 , Processed in 0.091848 second(s), 18 queries .
