Plans for Locking Weapons Wall Rack
发表于 2021-9-1 00:41:04 | 显示全部楼层 |阅读模式
I run a tactical shooting school and need to improve weapons security.  I have a reinforced concrete vault and need to fabricate a steel rack for wall mounting that would afford some great security (I realize pros will have a plasma cutter with  them!) from the amateur thief.  My problem is I have many shotguns, rifles, carbines, submachine guns, handguns and suppressors of all calibers and types so I need flexibility as to location of supporting hooks and securing bars etc.Can anyone point me to any plans/specifications?
Reply:Send some pics of the vault now and I'll give you some ideas of what I have in mind, if it looks like I think it looks like. My friends and I operate alot of [email protected] B & B Fabrication and Welding Inc.Spalding, MI.
Reply:I do not have pix and dont think they will help any.  Basically it is a rectangular room with reinforced concrete walls, ceiling and floor approximately 16'X9" with 93" ceiling.  It is dehumidified, lighted, alarmed and has one entrance--a 500 lbs UL certified prison door in steel frame secured to rebar in wall.  The wall area I pan to use is 62' long coming out of a corner of the room.  Basically I need a steel wall rack that will accommodate up to 20 long and subguns, 25 handguns and 6 suppressors of varying lengthas and diameters.  I want to be able to quickly confirm they are all in place at a glance so dont want to use a safe or cabinet.  I have an old Lincoln arc welder.
GMT+8, 2025-12-21 11:37 , Processed in 0.072790 second(s), 18 queries .
