Powcon models/specs anywhere
发表于 2021-9-1 00:41:02 | 显示全部楼层 |阅读模式
Having trouble finding a source of data on the different models. I need a TIG unit that will weld aluminum.I am just starting looking for a used unit and the Powcons seem like good prospects, but they are hard to find concise data. can you guys point me to a source for Powcon info, and maybe a short list of good used TIG models to keep an eye out for?Thanks,Clay
Reply:The PowCons are DC only so tig'ing aluminum with them is out, unless you want to tig very thick aluminum with DC and helium gas.  There is not HF start on most PowCons either.If you want to tig aluminum, choose an AC tig machine, like a Miller Dynasty or Syncrowave, Thermal Arc 185 or 300 ACDC, Lincoln Invertec or Precision Tig or HTP Invertig.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33The PowCons are DC only so tig'ing aluminum with them is out, unless you want to tig very thick aluminum with DC and helium gas.  There is not HF start on most PowCons either.If you want to tig aluminum, choose an AC tig machine, like a Miller Dynasty or Syncrowave, Thermal Arc 185 or 300 ACDC, Lincoln Invertec or Precision Tig or HTP Invertig.
Reply:If you want to do alum you probably want to say with a larger machine unless all you plan to do is thin stuff. My Syncro 200 is maxed at 3/16-1/4" alum. I'd be much happier with a Syncro 250 or bigger to do alum. Better yet a Dynasty 350.I've seen the older Syncro 180's used at decent prices. That or some of the really big older transformer machines. I've seen them used super cheap, but you need the space and juice to run them..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWIf you want to do alum you probably want to say with a larger machine unless all you plan to do is thin stuff. My Syncro 200 is maxed at 3/16-1/4" alum. I'd be much happier with a Syncro 250 or bigger to do alum. Better yet a Dynasty 350.I've seen the older Syncro 180's used at decent prices. That or some of the really big older transformer machines. I've seen them used super cheap, but you need the space and juice to run them.
GMT+8, 2025-12-21 11:37 , Processed in 0.217497 second(s), 19 queries .
