Probably a stupid question...
发表于 2021-9-1 00:41:01 | 显示全部楼层 |阅读模式
This is probably a stupid question but on a test I had it asked which way steel cools. From the inside to the outside or the outside to the inside or what.. I thought the answer would be from the outside to the inside but i'm not sure cause we're not allowed to know the answers after. It's stupid that it was on the test cause it was never written in the book.http://specific.net
Reply:Cooling is heat going from the hot side to the cold side.  The molten steel is hot, the air around it is cool.  The steel next to the air cools first.  The best laid schemes ... Gang oft agley ...
Reply:Thought so.. that question just pissed me off cause it never said it in the book so i thought it was some sort of trick question or something. Thanks for confirming thoughhttp://specific.net
GMT+8, 2025-12-21 11:36 , Processed in 0.197010 second(s), 18 queries .
