Addons For XMT 304
发表于 2021-9-1 00:40:59 | 显示全部楼层 |阅读模式
We have a XMT 304 in our shop and I have been wanting to get a wire feeder for it. I have been keeping my eyes open for a decent used S-22A. I was at an auction yesterday and ended up buying a S-54D for $50. It looks to be in good shape, but I haven't had a change to even plug it in yet. I don't know anything about this feeder, but decided for the price I couldn't go to far wrong. I also bought a Miller HF-15-1 high frequency starter for $25 for the same reason.Now for the questions. 1. Will this feeder work with the XMT? At the very least I believe that I will need an adapter of some sort. Correct?2. Is the S-54D a good feeder? I haven't been able to find much info on them. 3. Does the HF-15 serve any purpose with the XMT? I don't have much use for TIG and I know the XMT is TIG capable without the HF.Thanks.
Reply:The HF unit allows high frequency no-touch start in the tig mode.  It may also have a gas valve and gas timers, or it may not, I'm not familiar with the HF-15-1, only the HF-251D-1.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Yep, that is the one. My feeder is a dirtier version of the one above.
Reply:I had a S54-E feeder that I used on a XMT300. When I upgraded to a XMT350, I bought a 60 series. I have been so busy with other projects that I have not even used my XMT350 yet!!http://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Originally Posted by 7A749How those rollers working out for you??
Reply:Originally Posted by 7A749PM me if you need a cord. I get about $75 for one shipped to your door. brand new materials, same as Miller's. Satisfaction guaranteed.That's an easy $50 less than Airgas is going to charge you for one. You can find them used, or convert the one you have by taking off the plugs & installing the 14 pin connector.The bad news on that is your LWS is probably going to want $50 for the plug kit.
Reply:I had a chance to take a closer look at the feeder today. It is indeed like the S-54D that was posted earlier, but it also has a Pulset box on top of it. I wasn't familiar enough with it to even notice the difference at first glance. What little information I have been able to find on the Pulset would suggest that it is only compatible with the Pulstar 450. Is this actually the case, and if so, is the Pulset worth anything?
GMT+8, 2025-12-21 11:39 , Processed in 0.092865 second(s), 18 queries .
