hard-facing rolls
发表于 2021-9-1 00:40:58 | 显示全部楼层 |阅读模式
Any body know of anyone in the Southern California region that has mobile capabilities for hard-facing my roll crusher
Reply:I've not messed with hard facing, but a couple other mobile welders I know have done it with hard facing sticks.  What part of so.Cal are you in?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:When I retired from the crushers in '02, not many were being used in the northwest where I mainly worked. The co. I worked for had a mobile setup w/ 2  600 amp welders using 9/64" flux core wire and a carriage for each to build up and hardface the rolls.But that was 20 yrs ago when they last used rolls. We went to impacts and fine head cones to make the fine aggregates You might try some of the aggregate trade magazines to see if you can find someone that still does it. And by the way, you probably already know this, but if your shells are worn down much you'll need buildup before hard rodding.                    That's all the help I can give ya,        MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by DesertRider33I've not messed with hard facing, but a couple other mobile welders I know have done it with hard facing sticks.  What part of so.Cal are you in?
Reply:John, I have to ask: what are you crushing in downtown LA?                                   MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Actually, I can think of lots of things that should be crushed in Downtown LA ....
Reply:John, I sent a PM with a contact for you.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-21 11:37 , Processed in 0.181053 second(s), 18 queries .
