Dialing in Heat and Speed
发表于 2021-9-1 00:40:52 | 显示全部楼层 |阅读模式
Was playing around tonight practicing on some scrap and got thinking.What are some visual/sound/obvious ways to help you dial in wire speed and heat.Any rules of thumb to go by judging by the weld that will tell you to turn up your speed, lower your speed, heat, etc?
Reply:You wan that frying bacon sizzle sound.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:For a given voltage setting you can watch the length of arc as the wire feed is adjusted.  Too high a feed and the arc length closes and will momentarily stub on the material.  At the other extreme you will notice the arc will max out until you have an unmanageable welding arc.  With practice at a given voltage range such as short circuit voltage ( 19 volts) you will recognize that sweet spot/arc length.  I tend to set my voltage then tune my wire speed.  Others do the opposite. Once I have it close I will then tweak the voltage if I want a more fluid puddle for example.
Reply:Originally Posted by brendonvWas playing around tonight practicing on some scrap and got thinking.What are some visual/sound/obvious ways to help you dial in wire speed and heat.Any rules of thumb to go by judging by the weld that will tell you to turn up your speed, lower your speed, heat, etc?
GMT+8, 2025-12-21 11:36 , Processed in 0.077647 second(s), 18 queries .
