tack with gas rod then TIG?
发表于 2021-9-1 00:40:49 | 显示全部楼层 |阅读模式
Hello,Can I tack 2 pieces of thin wall steel tubing with a gas rod using oxy/acet then have a TIG welder do the whole joint? Will the slightly different filler metals interfere?Thanks
Reply:A lot of people who O/A weld use tig rods.  They are very high quality.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:If you can tack it why not weld it all?What is the point of having some one else Tig it?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Mild steel has a tensile strength of about 36k. O/A rod comes in 45k, and 60k. TIG rod is 70k. Yes you can TIG over O/A tacks. I also wonder why? 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Thanks guys. So I might as well use a TIG rod with my O/A to tack it?I'm doing this because I dont know how to TIG (but do know how to use O/A), and I want the nice clean TIG look on my project. So I wanted to see if I could tack it all together then have a pro TIG it up.
Reply:I'm interested to see if the TIG has any problems with porosity, oxidation, or irregular appearance due to the OA tacks.
Reply:Should be no problem, as long as all oxides are removed. Its not like trying to TIG high carbon steel."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:Originally Posted by calikid2006Thanks guys. So I might as well use a TIG rod with my O/A to tack it?I'm doing this because I dont know how to TIG (but do know how to use O/A), and I want the nice clean TIG look on my project. So I wanted to see if I could tack it all together then have a pro TIG it up.
Reply:It is structural... A bicycle frame I am going to make. It is thin wall chromoly.I don't have the skill to do a full clean O/A weld.Will the O/A tack work followed by TIG?Any ideas of how I can do this?
Reply:Originally Posted by calikid2006It is structural... A bicycle frame I am going to make. It is thin wall chromoly.I don't have the skill to do a full clean O/A weld.Will the O/A tack work followed by TIG?Any ideas of how I can do this?
Reply:Great, thank you.
Reply:If you do three tacks at 120*, then the TIG guy can do three more tacks between yours. Now he can weld from his known good tack, toward the unknown O/A tack. If it causes trouble, he can safely grind out the three O/A tacks and finish with the TIG. 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:just practice and get your chops up.  I just started welding a month ago, i know my welds a fugly as sin, but its not gonna get better if practice doesn't happen.
Reply:A possibility is to braze it with a high strength nickle brazing rod.That'll mess with the tubing grain structure less .Brazing is traditional for bike frames
Reply:I interchange between O/A and tig on home projects all the time. never had a problem as long as you clean it befor doing the tig. Though I've never welded chomoly befor, I don't think having a few specks of metal with 45k tensil streangth under a weld with 70k tensile will make much difference on a bike frame. If you want, you could switch to tig rod for the O/A or you could ask the tigger to use your O/A rod when welding the frame. Though I think you should practice your welding so you can do it yourself. Like I said, I do tig and O/A. If you can do O/A, learning tig shouldn't be to difficult for you.
GMT+8, 2025-12-22 09:19 , Processed in 0.252353 second(s), 18 queries .
