Which grinding stone for Tungsten sharpening
发表于 2021-9-1 00:40:48 | 显示全部楼层 |阅读模式
I'm continuing to add to my little workshop, to facilitate using my new TIG welder, I bought a new bench grinder (the usual type with a stone on each end of the shaft).I will use one end for Tungsten sharpening, given my level of skill it'll probably get a good workout for a while.I am not sure what the best grinding stone is for Tungsten sharpening, any advice would be appreciated.  I'll be using 2% (Red) mostly, both 1/16 and 3/32.Regards to all.Working on cars and bikes is my hobby, learning to weld the pieces together is my quest.
Reply:If one stone is more coarse than the other, I would use the less coarse stone. Other than that, I have not heard of a specific stone more conducive to grinding tungsten.
Reply:Its good to have something in the 60 grit range for doing the rough work and removing most of the contamination/shaping then its nice to have something quite a bit finer to finish it, maybe 220-400 range.Have we all gone mad?
Reply:I use a Diamond wheel on a dremel tool mounted vertical in there little drill stand.  (it works great)  spins at 5000rpm (I chuck the tungsten in a cordless drill)  I still do my share of dipping when my shakey hands are not in sync.I have been using the same little wheel for over 6 months. (If I am sharpening a new tungsten I will get it started on my dedicated green wheil in a 8 in bench grinder)Hope this helps Attached ImagesA rich man is not the one who has the most but instead one who needs theleast. Retired IUEC local 19AK Bush pilot,  Chaplain  CMA Chapt 26victor torchesMiller110v migDynasty 200dx (new in Dec 08)Hypertherm PM-45MM-252 (new 2/09)
Reply:UltraChop, I have a very similiar setup, LOL. I built a cheesy stand to hold my Dremel and a guide to put my tungsten at something around 20° Attached Images
Reply:The green wheel for me.Grinding longitudinal of course.
GMT+8, 2025-12-22 09:21 , Processed in 0.106018 second(s), 18 queries .
