Explanation of DIN Ratings?
发表于 2021-9-1 00:40:48 | 显示全部楼层 |阅读模式
HiCould someone in the know explain the meaning of the numbers in DIN ratings on A/D helmets? For example, this is mine: 4/ 9-13.9-13 is the variable part. But what's the digit 4 mean? I don't need to know, but am curious.Thanks,Mark.
Reply:this should explain. http://www.minoxlab.com/Don_Krehbiel/mpl/dkasa.htm
Reply:Originally Posted by markannabHiCould someone in the know explain the meaning of the numbers in DIN ratings on A/D helmets? For example, this is mine: 4/ 9-13.9-13 is the variable part. But what's the digit 4 mean? I don't need to know, but am curious.Thanks,Mark.
Reply:Don’t know if anyone’s ever tried it. Set your hood to the darkest setting and look at the sun, you’ll be able to see the spots on the sun.
Reply:Quite simply:  the 4 is the clear shade number.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Thanks very much.
GMT+8, 2025-12-22 09:26 , Processed in 0.090648 second(s), 18 queries .
