timer board in 255C
发表于 2021-9-1 00:40:40 | 显示全部楼层 |阅读模式
Just installed timer board in a Lincoln 255C. Run-in seems to work fine but the spot timer does not. Any ideas?Thanks Mark
Reply:Can you post a schematic of the welder an d the timer board?  Might help.awright
Reply:Called Lincoln this morning and they said it's likely in the timer itself. New one on the way.Thanks,Mark
GMT+8, 2025-12-22 09:26 , Processed in 0.151599 second(s), 19 queries .
