My Carts
发表于 2021-9-1 00:40:35 | 显示全部楼层 |阅读模式
Since in a previous thread someone amde a good comments about my cars I will post some pictures. Those were my very first projects Attached Images
Reply:my table Attached Images
Reply:My chop saw?bench grinder/angle grinder stand Attached Images
Reply:I really like that little yaller welding cart.  Looks kinda like it started out in life to be a chair & found a higher purpose.  Since I don't have a wife around who requires me to mop my shop floor every day I have to have larger tires though.  Sheesh, its been a while since I've noticed a reflection in a concrete floor!  Does she make you wax and buff it too?
Reply:Now Cutter, don't be pickin on the youngun.  He's barely been at this weldin long enough to know witch way to point the gun.Give him a year or so, and he oughta have a barred gate to keep the wife in the house and a good deep pile of traction assist spatter on the floor.Didn't he already build the wofe a nice fume exhauster so the welding smell wouldn't get in the house?  The man is downright considerate.  Besides, his wife might be a great cook.Appreciation Gains You Recognition-
Reply:Originally posted by Franz Now Cutter, don't be pickin on the youngun.  He's barely been at this weldin long enough to know witch way to point the gun.Give him a year or so, and he oughta have a barred gate to keep the wife in the house and a good deep pile of traction assist spatter on the floor.Didn't he already build the wofe a nice fume exhauster so the welding smell wouldn't get in the house?  The man is downright considerate.  Besides, his wife might be a great cook.
Reply:How about some more pics of your chop saw/ grinderstand. I like it. Nice idea.mikeI do understand that's why I drive a Toyota!!
Reply:Wow!  Nice setup.  Can you give us some more angles on the chop saw/bench grinder/angle grinder stand?
Reply:Here there are more angles of the chop saw stand (I hope Chuck is not going to get mad for too many pictures) As I explained, my space is very limited and I had to make everything portable. Attached Images
Reply:This is an outlet for the chop and grinder Attached Images
Reply:This is another electrical outlet for the angle grinder and a dremel or for any other needs Attached Images
Reply:I made all the electrical wiring inside the stand for the outlets Attached Images
Reply:Another angle Attached Images
Reply:And this is my little corner. Attached Images
Reply:Amalgam: Great shop, and good job on all your projects!
Reply:Cutter, I am well acquainted with Walter Williams beleifs, and I sort of think he runs his household pretty much the same way Hagar the Horrible runs his.  Your credentials as a Marriage Counselor are doubtless impecable, but ya just oughta point out to the younguns that when you got divorced, She got the Oil Well, and you got the SHAFT, sort of a truth in advertising thing, so the younguns can shop intelligently.Amalgum, WAY too much yellow paint!  You also should consider a couple more rungs across the base of the grinder stand to minimize stress on the top corners.  Another thing everybody needs to remember, welding helmets are magnets to spray paint, so keep the helmet out of the paint area.Appreciation Gains You Recognition-
Reply:Nice job, Amalgam. Your shop looks very good and clean!.
Reply:I like your tables, it looks like they keep you organized.  You should put a bushing or something where the extension cord enters the leg or it might light up your life.
Reply:just a question as I am new to welding. What did you use to hold your steel in place (ie: your legs of your chop saw stand)?? - did you just tack them and then align them, or do you have a helper (human or mechanical) - Sometimes I try to imagine the steps in welding something. What you weld first, what last, what is the easiest angle for your gun to plan which steps come first.
Reply:Once again I realize why this is such a great forum.  Great projects and great ideas.  Well done!
Reply:hey, how does that fume hood work?  You want to give us a little bit more detail on that one?  Great projects!
Reply:Someone doing some fabbing.  Nice jobs and great ideas.
Reply:Cutter, nice grinding cart, but, you definitely need to add a grommet where that orange power cord goes into the frame. If not, it'll cut away the jacket and ZAP! You're toast!
Reply:Can anyone post a pic of a good welding bench fixture holder? I want to have a way to temporarily mount a vise to my cart and I'm not sure what the supports should look like. Thanks!-David
Reply:Nice!, I really like the bench grinder/chop saw cart. Maybe at something that extends out the sides for when your cutting up longer pieces too.triffid,   in two of my tables I welded a 2 1/2 in square tube in the table and make a plate with a 2 in tube wleded to it and mount the vise to it.  The vise actually fits down in the tube like a reciever style towing hitch does. works pretty well.Give me some days to post a few pics.  ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by Hammack_Weldingtriffid,   in two of my tables I welded a 2 1/2 in square tube in the table and make a plate with a 2 in tube wleded to it and mount the vise to it.  The vise actually fits down in the tube like a reciever style towing hitch does. works pretty well.Give me some days to post a few pics.  ~Jackson
Reply:triffid, I weld my reciever tube vertically in the corner of the table I make it about 12 inches long, and weld then grind it flush with the top so you can lay out stuff without hitting it.    If you make the reciever 12 inches and the insert 12 inches mounted vertically, you will not have much slop and it will stay in without the use of pins or nuts.   I have never had one come loose, and mine catch all kinds of hell.  Good luck ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Amalgam, you did a great job on the carts.  I would like to know what you did to your floor.  I am currently finishing off my garage and am up in the air on what to do to the floor. I would like to have something other than unfinished concrete.  I am afraid of paint or epoxy for fear of welding/grinding sparks melting the finish, and also the possibility of my jack stands denting the surface.
GMT+8, 2025-12-22 09:20 , Processed in 0.127733 second(s), 18 queries .
