My Cart
发表于 2021-9-1 00:40:34 | 显示全部楼层 |阅读模式
well, here's what I came up with for a plasma/mig Cart.  The mig is bolted on through the case, you need to take the mig off to get the plasma out and the cart is locked to the tool box through the work bench legs.  (and the tig is just sitting there)
Reply:Nice, how do you like the pro-cut 55?  I need a plasma torch.
Reply:It's an awesome torch, just earlier today I was zipping through some 1 1/4" plate like butter.  Unfortunatly, it's a reason that I need a bigger compressor, or bottled air.Huh, for some reason, when I took that pic, the bottles wern't on either the MIG or Tig...Weird.
Reply:The 55 is rated at 3/4 " cut max. How fast can you go through 1 1/4 plate??
Reply:I use the thermal dynamics pak master 100 and I cut 1" material but don't exactly zip through it.
Reply:Originally Posted by KEENAVVThe 55 is rated at 3/4 " cut max. How fast can you go through 1 1/4 plate??
Reply:Man ctardi,You keep your metal working stuff a heck of a lot cleaner than I do.  Your stuff looks like you just pulled it out of the box.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by smithboyMan ctardi,You keep your metal working stuff a heck of a lot cleaner than I do.  Your stuff looks like you just pulled it out of the box.
Reply:I like the beer holders on top the tig, was that xtra?j/k!
Reply:My computer has a beer holder.  You just have to press this little button on the front and it pops right out.Smithboy...if it ain't broke, you ain't tryin'.
GMT+8, 2025-12-22 09:33 , Processed in 0.126618 second(s), 18 queries .
