Need help getting AWS certified in Lexington KY
发表于 2021-9-1 00:40:26 | 显示全部楼层 |阅读模式
Shot an email off to AWS and they said they don't have an accurate database of who could certify me in my area, Lexington KY.  Does anyone know who I should talk to around here to get AWS certified or maybe how I could go about finding out who in my area can?  AWS said to locate a local NDT lab and maybe back track someone from there, but I'm not even sure how to do that.As always, all helps appreciated.
Reply:Contact Knight school of welding to see if they can direct you to the certification facility in your area, you can also talk with some of the welding supply shops in your area and they should be able to either direct you or may offer it as a service.  We have a local supplier here by the name of Arcet that offers some testing services for things like 6G.
Reply:Contact Mactech in Louisville or Accu-Tek, Team Industrial Services aor HC-Nutting in Cincinnati. You might check with the local V schools or the KCTCS.
Reply:Thanks guys.  I'll be following up on all the suggestions.
GMT+8, 2025-12-21 11:57 , Processed in 0.087907 second(s), 18 queries .
