Gift Idea
发表于 2021-9-1 00:40:22 | 显示全部楼层 |阅读模式
I’m sure I’m not the first person to think of this, but I had to come up with something for a company Christmas party gift exchange.   The gifts are supposed to be humorous so I came up with a bank “designed for a person with little self control”.    Since there is no removable plug, there is no easy means of getting the money out.    Basically, it’s a 7” long piece of 4” x 4” x 1/8” wall aluminum fence post with plates of 1/8” thick aluminum welded to each end.     Before welding the top plate on, I cut the coin slot by drilling two 3/32” holes, 1.25” apart and cutting out the slot between them with a cutting wheel on a die grinder.  I had to clean up the slot with emery cloth.    Since my welds look like crap, I ground them smooth and polished the whole thing to look as if it were cut from a solid chunk of billet.   I should add that before welding on the top, I dropped in a dozen or so 1/4"-20 nuts to foil any attempt to shake out the money.    It was such a hit at the party, I have been asked to make several more.    I’ve also been asked to make one in steel, using a piece of 4x6 and ¼” plate. Attached ImagesThere are no small projects
Reply:Mean is what I would call it.  Yep, just plain mean....I like it.  Sounds like a good gift for my kids.Smithboy...if it ain't broke, you ain't tryin'.
GMT+8, 2025-12-21 11:59 , Processed in 0.069542 second(s), 18 queries .
