best machine for high freq up to 1/2
发表于 2021-9-1 00:40:18 | 显示全部楼层 |阅读模式
i need to weld 1/2 alum plate. high freq req for smaller jobs also.  will be welding thinner al and ss plates in tig config. the 1/2 alum will be the thickest.mostly need it for a/c high freq alum and dc tig as i have a mig already.no preference to manuf but there are so many machines avail. suitcase models/synchrowaves/idealarc/inverters...how to choosedoes anyone make a portable welder/genrator thats got high frq built in??thanksgary..my aircrafter finally gave it up...so the search is on for a unit to do what it was doin
Reply:The only welder/generator I know of with built-in high freq was the old Trailblazer from the 80's, I think it was the 44D.  A big monster of a machine compared to Trailblazers currently made. You can use a Trailblazer 302 with an HF251D1 high freq unit to do mobile AC tig.Possible tig machines for your application-Miller Syncrowave 350Miller Dynasty 350 (current)Miller Dynasty 300 (used)Lincoln PrecisionTig 375Lincoln Invertec V350Miller Suitcases are wire feeders for mig welding with seperate power supply, no tig capability with those.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:thanks...not alotta luck finding these used..i found a few synchrowaves and a cpl ideal arcs tho. dont need to be portable. itll be a shop unit. i can get a synchrowave or a idealarc for abut 1500 or so with coolers...which one ya like better..im thinkin the miller is a better unit..
Reply:precision tig 225???
Reply:I prefer Blue, so I would choose the Syncrowave.  PT225 is too small for your very thick aluminum application.  The 300-class machines are what you want.I only mentioned portable because you asked about it.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:i made an offer to a guy for a 300a synchrowave for 1200 bucks.he took itcan a 3 ph machine be made into single phase or can i get 3 phase in my barn??thanks for the help...the wiring part of it espgary
Reply:Gary,Without a rotary converter (and maybe not even with one) you can't operate 3ph on 1ph.Your power company can tell you if "heavy power" is available, but if you have three transformers on your pole instead of just one, 3ph *should be* available.
Reply:Syncrowaves are single-phase machines, unless you got ahold of a special model made for foreign countries or something.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:it was on craigs list..i havent seen it yet..maybe tonite but i think ill get him to send me the data plate info first..if not ill keep lookingthanksyou guys are greatgary
GMT+8, 2025-12-21 11:57 , Processed in 0.134744 second(s), 18 queries .
