Can you really do this?
发表于 2021-9-1 00:40:17 | 显示全部楼层 |阅读模式
Reply:My Thoughts exactly 7A749 Just thought I would share this
Reply:Originally Posted by 7A749A real winner there. Since when did Johnny Welder start posting You Tube videos of welding on gas tanks??
Reply:So many things wrong here.  No way I am climbing underneath that car.
Reply:Well I can sure think of a bunch of things that could and properly should have happened. That is one very lucky dumb_ss.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by 7A749Yup. Looks like you can.You can stick your head in a lion's mouth too.......The beer, shorts & tee shirt make it all the more convincing. I suppose he had flip flops on too.hen did welding on gas tanks?A real winner there. Since wJohnny Welder start posting You Tube videos of ?
Reply:You have to keep in mind that this particular way of repairing a gas tank only works when mixed with alcohol. DO NOT try this sober under any circumstances, it just won't work!I am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:"Fools rush in where angels fear to tread"!!!!! The sad part of putting it on you tube is some unfortunate fool will try it w/ deadly results.                                        MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Few years ago, in the next county, a welder and a helper were running pipe connecting new tanks to an oilfield storage battery. From what I understand someone failed to close a valve on the old tanks, fumes and welding, welder was injured and the 18 year old helper was killed. Just this week a shipyard worker was killed on a refit job. Explosion of undetermined origin. I choose not to impair my judgement or play with fuel. Not to mention that guy must have never seen a hydraulic system fail. There are too many pieces of rubber in the hydraulic system on that tractor for it to be trusted with ones life. First rule of lifting, never be under the load, never. We had a 2000 pound rated hoist fall from its jib(hook seperated from hoist body) nearly took a guys head off.But in that guys own words "sweet"!Ranger 250 GXTSmith Gas Axe
Reply:It's OK he is from CANADA.  What a dumb _$$!
Reply:In his defense, the gas wouldn't have blown up, though he could have had a serious fire in no time. But on the whole, STUPID!!! It's people like this that make me believe that there should be a licsense required to buy and operate welding equipment.
Reply:Did he say "nitrous" instead of "nitrogen".  Guess he doesn't know nitrous is an oxidizer!  Gasoline and nitrous oxide makes a liquid fueled rocket.Did anyone count this guy's fingers and toes.  I'm sure some must be missing by now.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:All of the above, one lucky maroon! Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:he was kind of a moron....but hes right. co2 will push the gas fumes from the tank. i am more living proof that it works because ive done it myself. i removed the gas tank and emptied it first, but yeah co2 will do that! i used dry ice, same thing though.
Reply:If the gas filler spout still has the little "door" in it, I don't see how he got much CO2 in there. I think the only thing that saved his dumba$$ was there were more gas fumes than O2 in the tank and therefore couldn't ignite. I might be wrong about that.                                  MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:It was a legitimate (CO2 to displace oxygen) way to perform hot work a long time ago, but it's worthless without being able to monitor oxygen content in the fuel tank to be sure you are well below the lower explosive limit. Bottom line is, it does work, but don't try it at home! If you mess up there could be tragic consequences.  BTW that's Dave's farm.  They are crazy drunken Canadian hillbillies. Most of the videos have some danger potential but are pretty entertaining.
Reply:Originally Posted by mla2ofus"Fools rush in where angels fear to tread"!!!!! The sad part of putting it on you tube is some unfortunate fool will try it w/ deadly results.                                        Mike
Reply:Worst thing was how poorly he had that wire feeder running. Johnny welder boy wounder,  might jump in here and tell him what for about the right way to hang a car from a bucket.
Reply:apparently he hasn't seen the Canadian "work safe" TV commercials their mini snuff films in disguiseVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:wow.. just.. wow. this is an epic, multi-level wow.http://kawispeed.com/ -moderator and tech deluxewww.myspace.com/trickortrack -cuz i have no life
Reply:Aside form playing with a potential bomb.   I don't understand why he wasted a fill on a co2 fire extinguisher when he had a bottle of shielding gas sitting right there.      I have no idea how I have lived to be as old as I am.  I have welded gas tanks years ago when I was much younger & dumber.     Even then not on the car, not with gasoline in them, & definitely not under a DEAD fall.      I'll not go into the method I used as I don't want to contribute to someones demise.IF IT WORKS, DON'T FIX IT2 Lincoln CV-300 / LN-7 GMALinde-VI 253,400 & 450 w/MIG35 feedersCNC Table with Oxweld O/A & Hypertherm 1250G3Lincoln Ranger GXT 250Hobart-MicroWire 300ESAB Heliarc 161ESAB-Mobilemaster 2 CC/CV Feeders& more
Reply:Sure YOU can do it, with ME far away.Tough as nails and damn near as smart
Reply:He needs to take the wheels off, so that the car dropping flat on the ground, smothers the flame on his body.
Reply:I think this guy was trying to make a new Prevent It canadian PSAVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:good combination of short safety films showing what can happenCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.In real life though we do things like that all the time. Especially the demolition guys. I have cut oil tanks full of of number two heating oil. You just have to keep the temperature down. Keep a mist of water in the tank. Is it dangerous hell yes.        Sincerely,             William McCormick
Reply:Originally Posted by gtmpsgtIt's OK he is from CANADA.  What a dumb _$$!
Reply:i see there is a lot of respect for Canadians on this site, very dumb videos of dumb people doing dumb things can be found on youtube, from EVERYWHERELast edited by buckwheat_la; 11-27-2009 at 02:19 AM.
Reply:Yes it can be done but only if there is no oxygen inside to make it burst but then what about the bit of vapors that escape through the hole (and the bigger one made by blowing through)? They probably will light.   Yeah, I like fire in my face.  Nice trick if you belong to a circus.
Reply:Looked at the rest of this guys vids. Wow is all I can say.
Reply:Originally Posted by jreynoldsweldingLooked at the rest of this guys vids. Wow is all I can say.
Reply:Well he did show that he removed one of the components of the fire triangle.  I think allot of the redneck schtick is just that, schtick for the camera which does make it funny and shocking for those of us here.
Reply:Originally Posted by 4sfedJust look at the "car"!  I especially like the exhaust.
Reply:He's Canadian, watch the "Davids farm car clean up update" on his you tube page and you'll find that he's making his own movies but also fighting the good fight against the local government.
Reply:"Can do", and "Should do" are 2 completely seperate things.  He did protect his shielding gas from blowing away with a nice piece of cardboard.  Wouldn't want porosity in that weld, now would we!
Reply:The camera guy didn't have much sense either.No one noticed his modified exhaust system!Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldNo one noticed his modified exhaust system!
Reply:I noticed, but thought that was "de rigur" for tractors in Canada?  Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:I know a former ship fitter. He said he has repaired navy fuel tanks, dropped a running shielding gas line in the tank first. Oh and make sure someone is guarding the vents so some dummy doesn't walk up and get a lung full of argon.Ranger 250 GXTSmith Gas Axe
Reply:I have purged gas pipline like that on 3" pipe, you could see when the gas ran out and started running argon. But I never got under a tractor bucket in shorts to weld tho.
Reply:I wouldn't do it with gas but we do it all of the time with diesel.  Just make sure the fuel level is higher than the weld.  I also inert the top of the tank with CO2.
Reply:But doesn't that contaminate the weld area?
Reply:In the case in the video, it certainly does.
Reply:Not very smart being under the loader without it supported as well. Not the safest thing in the world but not the dumbest thing I've ever seen either. I keep waiting to hear Dave and crew got their Darwin Award one of these days;.
GMT+8, 2025-12-21 11:51 , Processed in 0.476622 second(s), 18 queries .
