5/32 6010 / 1/8 7018
发表于 2021-9-1 00:40:15 | 显示全部楼层 |阅读模式
i am thinking on taking the lincoln elct. pipe welding class heres the delima the prerequsite is an (3) 3x12coupons in an X config with 1/3rds of root root hot root hot cover in v up and oh ive got the v up down ok i had 1 blurp in my tie in but overhead   thjats  differnt any tips or tech to help a guy out the clas is 3 weeks year round so practice is a must ive got a machine to take the test onmiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:e-mail www.lincolnelectric.com & go to ASK THE EXPERTS column on the left margin, i am sure they can help. you could also e-mail somebody there in ohio, that can answer  you
GMT+8, 2025-12-21 11:57 , Processed in 0.094123 second(s), 18 queries .
