Lincoln 225 running off a 5k generator
发表于 2021-9-1 00:40:15 | 显示全部楼层 |阅读模式
Until I get power to my garage I was planning on running my 225 buzzbox off my 5k generator, anyone done this? I know I won't be able to run it wide open but I'm only plannig on using 1/8 or maybe 5/32 7018 or possably 1/8 jets. I thought this was asked before but be dam**d if i can find anthing.....Mike
Reply:look for input specs.its : AMPS xVOLTS =wattsyou will be under powered but it will work220v  x   40a = 8800 widealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:It's been talked about several times actually. I vaugely remember someone trying it last year, but only managed it at very low amps. I want to say he might have ran 1/16" or 3/32" rod at best and the welds looked way cold.You really need a 12kw or bigger gen set to utilize that machine. Miller rates their 10KW engindrive generators at 40 or 42amp 220v aux power.Also most 5KW generators are 5KW surge and only like 4KW or 4.2KW cont. Make sure if you want to use a generator you are actually looking at the cont rating not the surge..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:You need at least a 10,000 kw generator to make it work, anything less and you will barely strike an arc. Even at peak power it will barely scratch off an arc, you will not be able to do much more than stick the rod to the plate and get a lesson in frustration.Oops, looks like me an DSW was typing at the same time.I am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:No way you're going to be able to run 5/32 7024 from that small generator with a power hungry buzz box.  With 6011 or 6013, probly 1/16 or 3/32, maybe 1/8.  I doubt you'd be able to use a 1/8 7018 or 7024 with it, probly have a frustrating time getting it to start.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Short answer: Nope.Longer answer:    Try a 15kw generator.http://lincolnelectric.com/knowledge...generators.asp  The best laid schemes ... Gang oft agley ...
Reply:We’re all in agreement, that you need a generator that will not only supply power for the continuous load but also the surge at start-up. 12 to 15 Kw generators will have 15 to 20 hp motors, that’s going to be $$$$.
Reply:Your better off selling them both and buying a used ranger or bobcat from your local craigslist. Sorry, I tried it once with an ac225 and troy-bilt 5500 and would not even burn a 3/32 7018 half way without tripping.
Reply:If ya had a maxstar you'd be in business.....My name's not Jim....
Reply:I was thinking of one of those units. I used one over a year ago expecting it to be a piece of crap but for the size of it I was very  impressed.I'd still rather get a gas portable and turf the genset, one less engine to service and it wouldn't be setting around as long not going. The poor generator I bought years ago after hurricane Juan hit in 2003 has maybe at the most 5 hours on it. The ex, wife at the time, kept whining that we didn't need it so needless to say I was praying for a power outage but alas it never came so I turfed the wife ....Mike
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-21 11:51 , Processed in 0.234857 second(s), 18 queries .
