Fun pipe notching job
发表于 2021-9-1 00:40:15 | 显示全部楼层 |阅读模式
This is the wall behind the Sam's Club off of I20 in Benbrook.It was an interesting job.  It was about a quarter of mile of wall that required a forty two inch double pipe rail barrier.  It couldn't be shop made because the it's grade was erratic to  put it mildly.  It needed to be built in place and it spec'd out with two inch  (2 3/8) schedule forty galvanized welded.I got the call.Lucky me. Attached Imageslife is good
Reply:A concrete coring company did the holes.  I machine notched the posts and then Quick Rok'd them in.  I'd tack up the top rail.  And then I'd come back and write the measurement of the length for the intermeditate rail to be cut and notched by my helper.Now I set my posts for grade and line by eye.  Since the coring guys weren't quite as concientious as myself and the boys who built the wall sure wasn't I had to have all my posts long and then I'd cut them for height, different for each hole.This is the same view after this section was complete. Attached Imageslife is good
Reply:No I didn't have the helper notching each intermediate rail with a portaband, silly.I made this for my Vogel pipe notcher.  After all we were working on the high side in that gravel area. Attached Imageslife is good
Reply:There were some challenging sections. Attached Imageslife is good
Reply:We could almost call this testing one's work while working. Attached Imageslife is good
Reply:It wasn't all high. Attached Imageslife is good
Reply:And like all good things, there is an end. Attached Imageslife is good
Reply:Wow nice work there harv.
Reply:that is a whole lot of pipe...my hat is off to u man.
Reply:Nice post. That had to be alot of work. How many man hours did that job take? If you don't want to share that info it's ok, I was just trying to figure out how i would bid that job
Reply:where did you get that nocher at? Its pretty cool never seen one like that.
Reply:Quite impressive wroughtn_harv.  My hats off to you, Great Work!
Reply:Originally Posted by metalmanNice post. That had to be alot of work. How many man hours did that job take? If you don't want to share that info it's ok, I was just trying to figure out how i would bid that job
Reply:Originally Posted by omoneywhere did you get that nocher at? Its pretty cool never seen one like that.
Reply:W-H...That looked like one heck of a project...nicely done. Do you bring in the pipe stock in galv. and only treat the joints with cold galv. compound?
GMT+8, 2025-12-21 11:57 , Processed in 0.091696 second(s), 18 queries .
