Fabricating radiators?
发表于 2021-9-1 00:40:11 | 显示全部楼层 |阅读模式
I am looking into doing a project for a friend, modifying or fabricating a motorcycle radiator. The problem I am having is locating a place to purchase radiator core. Anyone know where I can buy lightweight aluminum radiator core? Thanks!
Reply:I know I have seen them around.I thought I'd have no problem finding something with a quick search but no luck.Intercooler cores on the other hand are pretty easy to find.I imagine one would work very well for a radiator if it fit your size requirements. If you have no luch finding a rad core check these out.http://www.bellintercoolers.com/pages/lacore.htmlYou could also try someone who makes custom intercoolers and see if they can sell you a core or sugest someone who can.Lincoln precision TIG 275Millermatic 140 MIG
Reply:transmission coolers are about the size of some motorcycle radiators.  I dont know if you can run anti-freeze thats meant for radiators in tranny coolers though.  but tranny coolers are readily available from your autoparts store
Reply:Originally Posted by yoshimitsuspeedI know I have seen them around.I thought I'd have no problem finding something with a quick search but no luck.Intercooler cores on the other hand are pretty easy to find.I imagine one would work very well for a radiator if it fit your size requirements. If you have no luch finding a rad core check these out.http://www.bellintercoolers.com/pages/lacore.htmlYou could also try someone who makes custom intercoolers and see if they can sell you a core or sugest someone who can.
Reply:What's the purpose of the modification? Not enough cooling now or something?Lincoln precision TIG 275Millermatic 140 MIG
Reply:Originally Posted by yoshimitsuspeedWhat's the purpose of the modification? Not enough cooling now or something?
Reply:Try these guyshttp://www.rondavisradiators.com/Radiators.htmLincoln precision TIG 275Millermatic 140 MIG
Reply:I know sparco sells cores for intercoolersVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by yoshimitsuspeedTry these guyshttp://www.rondavisradiators.com/Radiators.htm
Reply:And I think ya meant Spearco
Reply:Bump, still on the lookout for a good source for aluminum radiator core.
Reply:just put two on there, like the Honda VFR.  I ride mine naked (bike naked, not me) and there's no cooling issue at all.  if you're gonna have one that extends all the way down low, might as well carry two.  do you have a weight limit?  VFR is a pig!are you modding CBR's?  or just general 600 i-4's?
Reply:Griffin Radiators & Thermal ProductsCall up Griffin.  They should be able to get you whatever you may need for a heat-exchanger core.
Reply:Originally Posted by oxy moronjust put two on there, like the Honda VFR.  I ride mine naked (bike naked, not me) and there's no cooling issue at all.  if you're gonna have one that extends all the way down low, might as well carry two.  do you have a weight limit?  VFR is a pig!are you modding CBR's?  or just general 600 i-4's?
Reply:Originally Posted by pisces_0Griffin Radiators & Thermal ProductsCall up Griffin.  They should be able to get you whatever you may need for a heat-exchanger core.
GMT+8, 2025-12-21 11:57 , Processed in 0.092425 second(s), 18 queries .
