Shop Press Questions...
发表于 2021-9-1 00:40:09 | 显示全部楼层 |阅读模式
I want to get a shop press, but do not want one that is too large.20ton units seem to be in the right price range and size physically, but not sure if they will do what I need.  What I want to do with it is buy a brake and be able to bend ~3/16 flat stock into brackets.  Will a 20 ton handle this work load?  I realize bigger is better, but really do not want overkill and something that will take up a ton of room.Most of pieces I build for suspensions are 4" wide and 3/16" thick steel.  There is also the occasional bearing that needs pressed on and off for gear changes.  Thanks fellas.Best Times with 434 Naturally Aspirated Vette60 - 1.261/8 -  6.37@ 107.25 MPH 1/4 - 10.08 & 134.9MPH1/4 - 9.60@144MPH
Reply:The press brake Northern has in my paper catalog for the 20 ton press lists the following sizes for steel,1/8" x 20" wide3/16" x 10" wide1/4" x 6" wide1/2" x 2" widehttp://www.northerntool.com/webapp/w...70_21896_21896The 40 ton one lists1/8" x 26" wide3/16" x 22" wide1/4" x 10" wide1/2" x 4" wideHope this helps..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Yes, the 20 ton press will do it.  I bend 1/4 in mine all the time with no problems.
GMT+8, 2025-12-21 11:57 , Processed in 0.090608 second(s), 18 queries .
