tig welding CUNI 6-g
发表于 2021-9-1 00:40:07 | 显示全部楼层 |阅读模式
i need some advice concerning a possible test on the above, i can tig weld good but i never ran CUNI what is the standard root opening, also is there any color characteristic i should look for. i will be checking amps on scrap first.
Reply:You'll probably want to provide more detailed information on the pipe size and schedule in order to get any meaningful feed back on this.
GMT+8, 2025-12-21 13:09 , Processed in 0.258613 second(s), 18 queries .
