Finsished Plasma Cart
发表于 2021-9-1 00:40:05 | 显示全部楼层 |阅读模式
Well the flux-core splattered all over hatteis and i didnt feel like grinding it out neither.The 6011 did a good job on the wheel plates..Last edited by Blueraven; 01-12-2006 at 02:00 AM.
Reply:great job BR  we wants picsIF it Catches...Let it Burn
Reply:TxR,My files are 640 x 480 abt 121 and 130 Kb but the dang server wont let me upload them.
Reply:Need to re-size pics to under 100 kb before they load
Reply:well ill try thisn one. if i even change it by one pixel or anytyhing, it makes the pci very small. Attached Images
Reply:Jeesh its tooooo small to see. heck. I cant reduce them below the 120 and the 130 kn that they are..
Reply:I was t\using PSP, I think i got it done with MS phto editor.. Attached Images
Reply:Herer's the other pic of the cart. Attached Images
Reply:Looks Good BR.  Very good job.  you rollaround well?  have good stabiltiy? Thats great job! IF it Catches...Let it Burn
Reply:HAHA yea those were kinda small! Glad you got that figured out. The cart looks pretty good.
Reply:I finished the concrete in my shop and its pretty rough and it rolls fine. Need to get it on a real flat sureface and see if my wheels are all the same depth. I measured for that. All the steel make sit pretty heavy so its stable so far.The PMX600 is a 40 amp cutter and works like adviertized so far. Tho i havenet tried to cut thick steel yet.Thanks for the kind comments.BR
GMT+8, 2025-12-21 13:10 , Processed in 0.076155 second(s), 18 queries .
