i have an old millermatic 35, until yesterday it was working good. now when i try to weld it does not sound like chicken frying(the sound it should sound like when welding properly) i get very sparatic poping sounds, and pools of weld,not rows. the wire seems to be feeding good, gas is good, checked the ground lead, so what else could it be. thanks, jasonLast edited by cowhead5065; 12-14-2009 at 01:51 PM.
Reply:gas full? does it have ac/dc swapping capabilities? is it set up for inner shield (no gas) while you're trying to weld with gas?I'm a noob with mig, thats all i can come up with.
Reply:no it was working fine then all the suden it just quit working like it is suppose to.
Reply:You might have lost a diode. Check with a multimeter to be sure. They're easy to replace and quick to identify.We want to see something like this in the signature line:Lincoln Ranger 250Miller Auto-Darkening Elite HelmetLincoln 100Lincoln MigMiller Spectrum 375Craftsman 8 galllon gas powered compressorLongevity 200amp Tig Welder LT-200D
Reply:Did you crank it way up? Sounds like it might be going into globular transfer.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:i have been welding with in the highest position
Reply:Try adding more wire speed. Pictures will help us help you as well....
Reply:cranked the wire speed all the way up and that definately helped. seems like the wire gets kinked, so do i need to replace the liner? thanks for all the help
Reply:Originally Posted by cowhead5065i have been welding with in the highest position
Reply:Originally Posted by cowhead5065cranked the wire speed all the way up and that definately helped. seems like the wire gets kinked, so do i need to replace the liner? thanks for all the help
Reply:will do thanks for all the help. jason |
