cutting a triangle out of plastic
发表于 2021-9-1 00:39:57 | 显示全部楼层 |阅读模式
I want to cut a triangle out of plastic. I would like to make the triangle about 2 feet x 3 feet long.What is the best way to cut this sort of angle?Band saw?
Reply:I would think the bandsaw would work.  The biggest thing is the blade and speed you cut it with.  If it's going to fast the plastic will melt and not cut good.
Reply:Score it with a scribe or icepick and snap it.Jim
Reply:Jigsaw and a straight edge works, as does a table saw with a fine cut blade, or a band saw, as mentioned above.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:oh yea its 3/4" thick HDPE..
Reply:circular saw works fine. i had to make a lot of cuts in 20" pvc pipe, had a wall over a inch thick. makes shavings like crazy.
Reply:Skilsaw and a straight edge.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:skill saw
GMT+8, 2025-12-21 13:09 , Processed in 0.093353 second(s), 18 queries .
