The Flyer needs a finish!
发表于 2021-9-1 00:39:55 | 显示全部楼层 |阅读模式
Just got this cut out using my new TMX600.Cant decide how to finish it. May grind shiney and heat up. Not sure what that wld do.Any ideas are appreciated.  Attached Images
Reply:Wash it with a muriatic acid bath.  Rinse and let it set for a little bit.  When it gets the color you want seal it with a clear lacquer.life is good
Reply:harv,that will be a rusty brown finish right?BR
Reply:Originally Posted by Blueravenharv,that will be a rusty brown finish right?BR
Reply:Ill have to chk on a scrap..thaks..
Reply:I've recently been playing with products from metal finishes plus.  Their website is www.metalfinishesplus.com.  The copper plating and then  overcoating with the Rainbow Tourch is a nice finish -- then protect with plastic enamel.  The affect is much like shining it up and then heat treating, but after being copper plated, you can apply the rainbow tourch with a brush or QTip -- you could "paint" in the blues and purples in a patter to put "feathers" on the wing tips.Just my two cents worth.
Reply:Thanks for the tips..Thjey all help..Take Care..BR
Reply:If you want to retain a clear, glossy finish to seal for indoors or outdoors, try        Sherwin-Williams Automotive Finishes       " Ultra-Base 7        Kut-in        Clear Acrylic "
GMT+8, 2025-12-21 13:13 , Processed in 0.069775 second(s), 18 queries .
