gatedepot.com
发表于 2021-9-1 00:39:53 | 显示全部楼层 |阅读模式
im retarted...I was trying to reply to the guys question about gate designs. I found a bunch of stuff at gatedepot.comI have a job comming to install a 16" double swing gate. I'm not making the gate, he's had them made already and their soon to arrive so I don't have the specs yet.Anyway my first design issue is the posts. The customer is under the impression that the gate posts alone will support each 8' custome steel gate. I have rarely seen this done around these parts. Im guessing because the expansive clay soil will eventually spit it out.Last edited by TPnTX; 02-03-2006 at 11:46 AM.
Reply:here is something that may help you...here in ontario..our  electric supplier (hydro 1)  uses this  method on  their small out buildings in the  countrysideauger a post  hole  well below the  frost ...insert a post and  cement it in...after concrete sets  back fill to  just below the  frost line..slide a close fitting pipe over  the post that  comes  to jsut  above  ground level (this  pipe should have a grease nipple) pump the thing full of grease and then install the gates on the post that is cemented in....if the  frost heaves or the ground moves it will only move the outside pipe...your post is  cemented in well below  frost and in  virgin  soilhope this makes sense to you
Reply:Thankx for the info..Wow some of those gates sure cost alot$$$
Reply:Tom the biggest mistake I see made out there is too small a footer for a gate.  The rock gate hinge post is in a hole that's about three feet across and eleven feet deep.  Originally it was a two by eleven hole but when the concrete truck took out the star and overhead we had to take a crane and pull the gate post.  The post cut off four feet above the ground and the concrete footer weighed over seven thousand pounds according to the  crane operator.  For him to pull it I had to dig holes around it with my one foot auger.I don't do a drive gate less than six feet deep.  Most of them are deeper than that.  I can go eleven feet down and often do.If you want to see a gate click on this  When you do reward yourself by clicking on "gallery" at the bottom of the page.life is good
Reply:Thats some cool looking work.
Reply:Oh I know Harv I saw that back last April when I first discovered this forum and your webpage. Theres a link somewhere. Can you imagine making something like that? Wow...I appreciate your advise on the gate post. If you don't mind I'll bounce it off you when I get the specs.
GMT+8, 2025-12-21 13:13 , Processed in 0.190242 second(s), 18 queries .
