Airco 150 Heliwelder Help
发表于 2021-9-1 00:39:51 | 显示全部楼层 |阅读模式
I have an Airco 150 Ampere AC/DC MSM Heliwelder, stock# 1341-0245/serial# HG054855.Could anyone help with where I could get a foot control, Tig torch, and terminal lugs for the torch and ground cables. Also who made this machine for Airco. Thanks Darrell Attached Images
Reply:I dont think you can get a foot control for this machine.  I have a 300, basically the same machine.  Machine is made by Airco, just before getting bought out by miller.  Good machines.  I think the only controller you can get is a hand switch.  I use a miller diamondback or black diamond or whatever its called... its a piece of sh** torch, but its better than what it came with... and I have the hand switch taped up to it...  good luck..
GMT+8, 2025-12-21 13:16 , Processed in 0.093745 second(s), 18 queries .
