Hydraulic press
发表于 2021-9-1 00:39:45 | 显示全部楼层 |阅读模式
I am planning on building a 12-20 ton hydraulic press. Does anyone have plans or know a good resource for this type of project?
Reply:Evil,here's a starting place  http://www.megageek.com/shop/shop.ns...f?OpenDocumentjohn
Reply:http://www.frugalmachinist.com/pb.html
Reply:If have have a Harbor Frieght in your area, just go there and circle around theirs a few times. It's not a bad design at all.
Reply:HF has it on sale right now (almost) cheaper than most can buy the steel.  I wouldn't really consider it a real "20 ton" press unless you add some beef in critical areas, and a better jack too, but it's well into 12-20 ton territory IMO.  I just bought an air over hydro replacement jack for mine to make things easier...
Reply:Get in touch with me,I have a 50 ton press you can come look at it and get some ideas.MILLER ELITE WELDING HELMET 29 ROADSTERMM 251Lincoln Precision Tig 225Weldtech Cooler
GMT+8, 2025-12-21 13:29 , Processed in 0.091986 second(s), 18 queries .
