Bed for Ford Ranger
发表于 2021-9-1 00:39:41 | 显示全部楼层 |阅读模式
Hi everyone,    I attached some photos of the Ranger bed I've been working on. It sat outside all winter so it has gotten a bit rusty. Right now it is mostly tacked together. I also sent a pic of the drop hitch I made. Attached ImagesSure, I can fix it... I got a welder!!!
Reply:looks good.  Nice lil utility bedIF it Catches...Let it Burn
Reply:I am looking for a bed like that for my full size, single rear wheel 1987 GMC 3/4-Ton Pick-Up if you come across one.
Reply:Originally Posted by NJ PlowmanI am looking for a bed like that for my full size, single rear wheel 1987 GMC 3/4-Ton Pick-Up if you come across one.
Reply:I was thinking about building my own, but somehow I can never find the time to do a project like that with all the other little projects I have going on.  You are probably right though, but I figured if anybody had one laying around the back of their yard that was just taking up valuable space and rusting away I could take it off their hands for a few dollars.  Eventually I will just end up finding the time to make one, and once I start I will make it to my specs (probably end up taking forever when I start adding the extra's) but I just figured I would try and take the lazy way out and start with somebody elses base platform and then add my own touches later!
Reply:id add tool boxes underneath front and or rear of axle.  you can start simple and add on   custom i tell yaIF it Catches...Let it Burn
GMT+8, 2025-12-21 13:33 , Processed in 0.096181 second(s), 18 queries .
