Repair of "whoops"
发表于 2021-9-1 00:39:39 | 显示全部楼层 |阅读模式
Operator of this grader on snow duty said "I just barely hit the manhole". The drawbar broke clean,  vee'd it out, realligned and went to work then added a couple of "band aids".The break was between the hydraulic cyllinders.  I used 7018 and some scrap 3/4" plate.Think it will hold?Keithp.s. hope the pictures work Attached Images
Reply:Hey bro...that seems that it will hold pretty good, however probably you might want to run 6010 root pass so you´ll have better penetration and then cap with 7018 since it is very thick. However nice job!
GMT+8, 2025-12-21 13:31 , Processed in 0.089549 second(s), 18 queries .
