查看: 13|回复: 0
Finally the balcony project has begun
发表于 2021-9-1 00:39:38 | 显示全部楼层 |阅读模式
This has been a real PITA project even before I got started. I finally got the scrolls made thanks to a tip from  Harv. I found the blacksmith he told about and I got 26 scrolls at 15 bucks each. Here is the 1st pick...uh oh...wifes calling. Its supah time!!!
Reply:Looking good so far. This is the balcony where the gal wanted these at a special height isn't it??How do you get the mill scale out of the inside of the scrolls?
Reply:Yeah thats the one. The guy usually puts the parts in an old cement mixer with some blasting sand. Since these parts are too big he didn't. So I got a thing thats a cross between a barrel sander bit and a flap wheel. I'm sure there is a name for it but anyway I clamped a drill motor to the table and the held the parts to it. It worked okay. I started to sand blast them but I changed my mind.I tell you what although I enjoyed watching this guy work. King metal is like right around the corner. I just as soon go there and buy the fab'd stuff for half the price. So from now on if someone wants scrolls the can either pick them from the catalog or pay dearly for them. I'm not going to make much off this balcony. I didn't price it right but there is 400' of 6' ornamental fence that's mine to loose.So lesson learned and I always keep my word.I'll be finished with it tomorrow. Its really easy to build and I know my radius is right on so it will go in place easily.
Reply:So I got a thing thats a cross between a barrel sander bit and a flap wheel. I'm sure there is a name for it but anyway I clamped a drill motor to the table and the held the parts to it.
Reply:Congratulations TomLooks good.  Keeping your word will reward you many times over.   I usually dip stuff like that in muratic acid.  1part acid to 10parts water.  Let it sit for 2-3 hours then wash it off.  Scale wipes right off.  Rust comes immediately, so protect it.
Reply:man I wish I'd come here and asked before I started. The muratic acid is a great idea.I'm considering doing that today before I go any further.Like I said the flap disk only did okay.
Reply:okay this one is done except for some 4" legs. I'm going to think on it some first. I know I'll anchor the end into the stone wall. I left them long so I can cut to fit. the legs though will be either one in the center or two left and right of center.Not today though. I had enough and enough is too much.
Reply:oh and here is where is going to be installed.
Reply:very nice workChuckASME Pressure Vessel welder
Reply:Can't wait to see the end product!
GMT+8, 2025-12-21 13:32 , Processed in 0.270556 second(s), 18 queries .
