bead pic
发表于 2021-9-1 00:39:37 | 显示全部楼层 |阅读模式
.024 , 90/10 (c-10) gas on hh140 i'll get some more later Attached ImagesStangnetShop Full Of Stuff. Joey
Reply:what welder?
Reply:Looks like you're running fairly smooth and evenly there. Good job.I see that tiny pin hole at the end of the bead, I ended up with about 4 or 5 of those today out of a couple dozen short welds. I'm trying to figure out how to end without getting that. Having a hard time being consistant.
Reply:Originally Posted by cheeseclipwhat welder?
Reply:is it stick?
Reply:Originally Posted by cheeseclipis it stick?
Reply:Originally Posted by SandyHe's showing a bead done with GMAW. Solid wire with gas. MIG would be a real generic term if that helps.
Reply:sorry i am quite a newb but brands are different here in nz
GMT+8, 2025-12-21 13:30 , Processed in 0.097136 second(s), 18 queries .
