Are all weld caps the same shape?
发表于 2021-9-1 00:39:36 | 显示全部楼层 |阅读模式
It also seems that a well penetrating flat weld is not a good weld. The crown of the weld should have some height. So a vertical up hill, fill-it, but weld, Thats about all I can think of. These welds be basically be the same shape? I know a lap weld is a deferent animal.Vern
Reply:The profile should be on the positive side of flat. Here is a nice description of differences in profiles. Scroll down to the results photo's, you will see letter 'L' is a good profile.http://www.scielo.org.ar/scielo.php?...rttext&tlng=enCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by Vern2It also seems that a well penetrating flat weld is not a good weld. The crown of the weld should have some height. So a vertical up hill, fill-it, but weld, Thats about all I can think of. These welds be basically be the same shape? I know a lap weld is a deferent animal.Vern
GMT+8, 2025-12-21 13:28 , Processed in 0.103795 second(s), 18 queries .
