gjagnello
发表于 2021-9-1 00:39:25 | 显示全部楼层 |阅读模式
when tig welding stainless steel, how do you prevent that sometimes little hole at the end of the weld?
Reply:Are you talking about a "fish eye"? If so that is from pulling your arc away on a full puddle. rock your cup to the side and long arc it until your puddle dries up. hope this helpsAir vantage 500 on the 08' KWharris torchesl25 pro suitcasecomletely restored 1969 SA200 redfaceon my 08' duramaxPIMPN AINT EASY
Reply:If you're using a remote, let off the remote slowly while continuing to dip the rod while the puddle is still wet and shrinking.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-21 13:30 , Processed in 0.092728 second(s), 18 queries .
