It seems that a good toe is a sign of a good weld. Is technique or welder setup the key? Wire speed, Volt setting.Vern
Reply:I would say yes to both. You can correct a bit of either poor technique or poor settings with the other, but there's only so much you can do. If your settings are too cold, technique won't change the toes that much. Also if your heat is right and you move too fast, you'll still have issues..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by Vern2It seems that a good toe is a sign of a good weld. Is technique or welder setup the key? Wire speed, Volt setting.Vern
Reply:Hay Thanks, great stuff ! I've had welders for a long time. I have unproved, but a great weld, I have not.That's why the Lincoln 200 amp AC/DC is out and the Meg welders are in 2004. Now I'm thinking, the meg is out SP135 Plus, SP175 Plus is out and the Passport is in. The Passport will fit the Hypertherm 30 perfect.Vern
Reply:....my first thought when you mentioned a "good 'toe'": Attached ImagesLincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Thats the kinda toe i was thinkin of.
Reply:It's good to live in Canada, as you can see.Regards to all.Working on cars and bikes is my hobby, learning to weld the pieces together is my quest.
Reply:Oh you nasty horrible personNEKKID KNEES!!!!!! Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Aquafire all i can say is mmm,mmm,mmmm sweet as a Nova Scotia lobster and a can of cold beerFelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a 24 of MGD"
Reply:How y'all Cannucks even drink beer up there in that cold air???????? Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:farmersamm said "How y'all Cannucks even drink beer up there in that cold air????????"No problem sam we just pretend its summer and the beer doesnt freezeFelon Attached ImagesCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a 24 of MGD"
Reply:Don't know about the good toe but about a golden one? Attached ImagesCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by Felonyass Monkfarmersamm said "How y'all Cannucks even drink beer up there in that cold air????????"No problem sam we just pretend its summer and the beer doesnt freezeFelon |
