i apreciate tha advice
发表于 2021-9-1 00:39:20 | 显示全部楼层 |阅读模式
should oval and cocave  would be the  cross  section of a fillet  to reduce  base metal  stress, and have a maximun joint strenght? and also what is the rule of thumb  fot maitaining  proper electrode  work angle in  [ smaw]
Reply:Concavity is weak. The profile needs positive reinforcement. Convex bead profiles are stronger. Work angle is adjustable, but nominally it is determined by rod type, joint type, position, accessibilty. It just depends. Start at 90 degrees, then adjust to suit the situation. Push uphill with 7018, drag perpendicular with 6013, whip 6010. It depends.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-21 13:28 , Processed in 0.065346 second(s), 18 queries .
