is mig strong enough
发表于 2021-9-1 00:39:15 | 显示全部楼层 |阅读模式
ill be building a bumper  with built in to hitch  for my toyota pick upits going to be made out of 3x6x 1/4 wall tube im wondering if my standard lincoin 255with regular wire and a co2 argon mix will be strong enough or if i should take the extra work to stick weld it?thanks
Reply:Mig will do the job fine if it's done correctly.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:The question is not whether the welder will be strong enough; the question is will the .100 thick Toyota frame be strong enough to carry that weight??? I have built a LOT of Toyota bumpers, and I never go thicker than .125" material, with the exception of attachment tabs and tow hooks. The weight takes the nose down hard on those trucks, and is not necessary. I have dropped my Tacoma on it's nose from 5' up, and the .120 wall tube bumper took it like a champ.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:this is going to be a rear bumper/ hitchi would say i would a am quite good with a mig in hand ill try  and get some pictures tommorrow of practice
Reply:If you're "quite good", I would have thought you'd know the answer to your own question.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by bonez10this is going to be a rear bumper/ hitchi would say i would a am quite good with a mig in hand ill try  and get some pictures tommorrow of practice
Reply:Originally Posted by SundownIIIIf you're "quite good", I would have thought you'd know the answer to your own question.
Reply:sloppy 4ths!
Reply:It's all in the details, regular wire, CO2 mix? Is it ER70S6 or perhaps ER70S2? CO2 mixed with what and at what percentage? A Lincoln 255 has enough power to penetrate 1/4" steel just fine. The machine has the goods, it simply needs to be set up well. If you really want to penetrate steel with mig, study up on spray transfer mode.However, the project may not warrant steel this thick, as Rojodiablo has elaborated already.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-21 13:29 , Processed in 0.094220 second(s), 18 queries .
