Burner
发表于 2021-9-1 00:39:13 | 显示全部楼层 |阅读模式
First project, crawfish burner. Picked up two basketball goals that the school was throwing away, fiigured I could do something with them and this is what I turned out. The burner ring is one hoop, the other hoop was quartered for braces, and the two supports form the legs, a little round stock, some fittings, and here it is. I have been using a little burner dad made in the late 70's, so this was something I needed. Boiled a pot of water this morning, will put some crawfish in soon. Attached Images
Reply:That's a pretty good use of old goals.  I have a few laying around...hmmmm.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Excellent!!!!
GMT+8, 2025-12-21 13:31 , Processed in 0.066648 second(s), 18 queries .
