coffe table
发表于 2021-9-1 00:39:08 | 显示全部楼层 |阅读模式
made out of 1" square tube.  Made it for my mom's b-dayused hammered rustoleum spray paint (which got smudged due to handling before dry)
Reply:Nice!!!
Reply:Nice work. Maybe glue a thin skin of felt over those metal tabs. It comes in all colors, or just give it a quick spray.Again good job.
Reply:Ya, you don't want the glass to sit on those metal tabs.
Reply:Awesome - that table looks fantastic.
Reply:thanks guys, it actually does have some felt on the tabs that's nearly the same color as the paint.
Reply:What type of glass did you use Jakkyl ?From my experience Id recommend 6mm (1/4 ") toughened glass for that application if anyone is considering a similar project.I say that as I regularly see home made things with annealed glass ....bad idea and laminated glass doesn't have the strength toughened glass can offer though it does have some safety features.Lovely table mateBrett
Reply:Originally Posted by BrettWhat type of glass did you use Jakkyl ?From my experience Id recommend 6mm (1/4 ") toughened glass for that application if anyone is considering a similar project.
Reply:Good to hear
Reply:Originally Posted by jakkylthanks guys, it actually does have some felt on the tabs that's nearly the same color as the paint.
Reply:thats great!!nice job ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by SandyWell then I'd better just stick with "nice job" and keep my yap shut about needing pads for the glass.
GMT+8, 2025-12-21 13:28 , Processed in 0.091843 second(s), 18 queries .
