...zap! being ...zap!
发表于 2021-9-1 00:39:08 | 显示全部楼层 |阅读模式
some shots from the shop with me doing what i do when i have towelding bearing surface wear for re-machining on a anvil cutter roll (5"dia journal)Attachment 3469same roller diff viewAttachment 34707018 5/32 rod @180 amps dc+..puddle about 3/4 wide 1/8 highAttachment 3471pic of 'ol zapster himself..Attachment 3472enjoy ...zap!Last edited by zapster; 12-27-2007 at 03:34 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:good to put a face to the name.   looks good zapIF it Catches...Let it Burn
Reply:Originally Posted by zapstersome shots from the shop with me doing what i do when i have towelding bearing surface wear for re-machining on a anvil cutter roll (5"dia journal)Attachment 3469same roller diff viewAttachment 34707018 5/32 rod @180 amps dc+..puddle about 3/4 wide 1/8 highAttachment 3471pic of 'ol zapster himself..Attachment 3472enjoy ...zap!
Reply:Thanks for the pics zap. Nice seeing work in progress pics.pic of 'ol zapster himself..
Reply:Nice pics Zap.  Now the thing that really caught my eye is what appears to be a planner miil.    Whats the info on that and do you actually use it?As you can see my interests are all over the map.Dave
Reply:yes the planer mill ...its 25 feet long and 3 feet wide with a j head bridgeport for milling...(goes all angles)gets used on a regular basis between a table for the rollers for welding long stuffand being a regular old planer ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-21 13:29 , Processed in 0.092193 second(s), 18 queries .
