Alum spiral staircase
发表于 2021-9-1 00:38:49 | 显示全部楼层 |阅读模式
This was my first spiral staircase from aluminum. All tig welded. Also I used a small welding positioner with a lathe chuck adapted to it to twist the balisters. I wish I had more of these jobs- they are fun to build and bring in the cash.
Reply:Beautiful work.
Reply:nice work johnnyIF it Catches...Let it Burn
Reply:very nice workChuckASME Pressure Vessel welder
Reply:Very impressive!
Reply:Very Good !!!!!
Reply:That looks great! Nice work.
Reply:Very nice! Looks sharp!
Reply:That is fantastic !  Great job!!!
Reply:Johnny,This is a piece of good advertisement for your business.  I would take loads of pictures and keep them in a portfolio.  Did the balisters give any trouble?  I would have figured they would have bunches of surface cracks after twisting like that.  What alloy did you use for them?Smithboy...if it ain't broke, you ain't tryin'.
Reply:Good work- how did you contour the hand rail ?
Reply:Smithboy ,  The balisters are 6061 grade , and surprisingly the twisting didnt crack them at all. I simply counted the number of turns on the positioner and they all came out exact. The handrail ,of course, is the most dificult part. after the steps were all welded into place , I put the staircase onto pipe stands. The handrail is tacked to the first part of the STEP and the whole stairway gets turned while VERY carefully heating and guiding the handrail around it, tacking and clamping as necessary. A two man operation. Then gring off the tacks and move the handrail to the top of the balisters and weld it in . It takes some patients . Heating aluminum tubing has to be done just right with the right amount of pressure to bend without cracking it.Johnny
Reply:WOW!  That looks awesome!
Reply:now that is NICE!
Reply:WOW!!! Now thats bling,bling i wont let the wife see these pictures good job very professionalWELDERS GET BETTER PENETRATION
Reply:A regular work of art.  I read and article a few years back about a guy in Los Angeles, CA, called JohnnyWeld, and he was an artist as well.  Did all kinds of creative welding.  Really original, really good.  Are you the same guy?
Reply:Beautiful.
Reply:Thats insane.. see, thats the stuff i want to do for a living and sure, i can be pretty handy w/ stuff like building a wood fence in the backyard or im helping a friend put up an arena and pens for the bulls... but stuff like that.. were it has to work and look good.. damn..
Reply:Thats bitchin.   Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Hi Johnny,As a welding novice, I'm curious to know how long it would take somebody who knows what they're doing to make that?Scott
Reply:Scott,     The planning is about one forth of the job. That is because every floor to floor height is different . But once you get used to the calculations- and depending how detailed you want it to be , it's not hard. That one took me about 3 days by myself and one day with a extra hand. Plus , it gets easier  every time I put one together. The steps on that one took awhile  because I wanted the face of it to be clean looking so I had to tig  all the seams . Otherwise I  would have just bent the steps out of one piece of material. Scott, I got the feeling you wont be a novice for very long
Reply:4 days! Bloody hell. I'd still be thinking about where to start after 4 days. I'll be a novice till I can find a welding course to do.
Reply:Very nice!!DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Great looking job!!!!!!!!!!!!!
Reply:Man I have to say that you did an outstanding bit of work there. I'm more than impressed with it. Some of the neatest work I've seen done in a long, long time. My hats off to you bro! Great job, PaulMiller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.comReally nice work !John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Absolutely beautiful, I really like the diamond plate treadsSure, I can fix it... I got a welder!!!
GMT+8, 2025-12-21 14:30 , Processed in 0.113065 second(s), 18 queries .
