查看: 13|回复: 0
spoolmate 100
发表于 2021-9-1 00:38:47 | 显示全部楼层 |阅读模式
any one use one? I want to buy one for my 211 but I don't know if I'd be wasting my money Attached Images
Reply:Originally Posted by eyeball engineerany one use one? I want to buy one for my 211 but I don't know if I'd be wasting my money
Reply:Originally Posted by HANNYi have a lincoln spool i just got for my mig. Tuff to get use to welding with it because you have to push the weld and the gun is kinda hard to look over or around (altho the miller looks easier, the lincoln spool is on top of the gun where the miller is under) . You will need argon gas no other will work. The guns feed awesome and are great for tacking or welding but its not quite like tig.
Reply:What good is Photo?It is a Spoolgun designed to Operate within its Amperage Range.Also, Spoolguns are not just fer Aloominum.It works as advertisedEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1What good is Photo?It is a Spoolgun designed to Operate within its Amperage Range.Also, Spoolguns are not just fer Aloominum.It works as advertised
Reply:With your MM211, you don't get a choice of spool guns, the Spoolmate 100 is it.The questions you're asking have more to do with the welding machine the spool gun is connected to than the spool gun itself.   Hot starts, weld output power, duty cycle, arc characteristics, those are all power supply issues, so long as the spool gun has enough duty cycle to match the machine's output, which it should since it was made for that machine.Spool gun is not my first choice for welding around small diameter pipe/tube.  Tig and stick are slower and easier to control than the big bulky spool gun and fast paced mig process, though I'm sure there are many who use it that way and get acceptable results.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:yeah I know its the only one, I just want to know if its any good- the 211 with the spoolmate 100, or is it the equivilent to a home depot lincoln weldpack100? the spoolmate 100 compared to the next size spoolgun up which is like 800 bucks that can be ran off the 251 too much money for me, but I don't want to waste 300 bucks on the spoolmate 100 if its junk
Reply:Originally Posted by DSWWhat are you planning to use it for? If you want to do alum, it's the way to go, no question. If you want to do steel, then it depends. I have the 3035, a very similar gun. For alum it's great. For steel, it's nice to be able to load say .023 and not F with the big spool of wire in the machine for some quick sheet metal work, or pop in some SS to do something quick. The spoolgun is bulky and awkward compared to the standard gun, but with some practice you get used to it. Also it's nice when I need to get to places that I just can't reach with my larger machine, since mine spoolgun has a longer cord. Things like adding D rings to the ladder rack or fixing the expanded mesh on the window protector. Before I'd have to muscle the whole machine into the bed to work, Now all I do is get next to the truck and pass up the spoolgun.I don't think I have any scrap 1/8" alum right now, but I'll look tomorrow. If I do and the wind is calm, I'll try to run a few beads with it.
Reply:Originally Posted by eyeball engineeryeah I know its the only one, I just want to know if its any good- the 211 with the spoolmate 100, or is it the equivilent to a home depot lincoln weldpack100? the spoolmate 100 compared to the next size spoolgun up which is like 800 bucks that can be ran off the 251 too much money for me, but I don't want to waste 300 bucks on the spoolmate 100 if its junk
GMT+8, 2025-12-21 16:01 , Processed in 0.103300 second(s), 18 queries .
